Message 1 of 4
BT SmartHub disconnecting 20 times a day...SIP WAN DOWN
Been like this for 2 weeks, another engineer coming tomorrow...I've tried noisy line test and all is ok.
Product code:Smart Hub 2
Serial number:+091298+1901000617
Firmware version:v0.24.04.11017-BT
Firmware updated:Thu Jan 14 10:53:00 2021
Board version:R01
GUI version:1.71 05_06_2020
DSL uptime:0 days,00 Hours07 Mins32 Secs
Data rate:8.173 Mbps / 52.445 Mbps
Maximum data rate:8.473 Mbps / 55.825 Mbps
Noise margin:6.1 / 7.1
Line attenuation:10.0 / 22.0
Signal attenuation:10.0 / 22.8
Get this in the logs:
:41:38, 23 Feb.
PPP CHAP Receive success : authentication successful
12:41:38, 23 Feb.
PPP CHAP Receive Challenge
12:41:38, 23 Feb.
PPP: LCP up
12:41:38, 23 Feb.
PPP LCP Receive Configuration ACK
12:41:38, 23 Feb.
PPP LCP Send Configuration ACK
12:41:38, 23 Feb.
PPP LCP Receive Configuration Request
12:41:37, 23 Feb.
PPP LCP Send Configuration Request
12:41:37, 23 Feb.
PPP: Received PADS
12:41:37, 23 Feb.
PPP: Sending PADR
12:41:37, 23 Feb.
PPP: Received PADO
12:41:37, 23 Feb.
PPP: Sending PADI
12:41:32, 23 Feb.
PPP: Sending PADI
12:41:27, 23 Feb.
PPP: Sending PADI
12:41:22, 23 Feb.
PPP: Sending PADI
12:41:19, 23 Feb.
DSL Link Up: Down Rate=52445kbps, Up Rate=8173kbps; SNR Margin Down=6.4dB, Up=6.0dB
12:41:17, 23 Feb.
PPP: Sending PADI
12:41:12, 23 Feb.
PPP: Starting PPP daemon
12:41:11, 23 Feb.
WAN Auto-sensing detected port DSL WAN
12:39:03, 23 Feb.
SIP WAN DOWN
12:39:00, 23 Feb.
SIP WAN DOWN
12:39:00, 23 Feb.
WAN Sensing Auto sensing Complete, interface selected
12:38:59, 23 Feb.
WAN Sensing Auto sensing Running
12:38:58, 23 Feb.
12:38:57, 23 Feb.
VLAN id:101
Upstream error control:Off
Downstream error control:Off
Data sent / received:7.9 MB Uploaded  / 38.1 MB Downloaded
Broadband username:[email protected]
BT Wi-fi:Activated
2.4 GHz wireless network name:BT-J8A2MN
2.4 GHz wireless channel:Smart (Channel6)
5 GHz wireless network name:BT-J8A2MN
5 GHz wireless channel:Smart (Channel36)
Wireless security:WPA2 (Recommended)
Wireless mode:Mode 1
Firewall:On
MAC address:78:DD:12:0C:51:8C
Software variant:-
Boot loader:0.1.7-BT (Thu Nov 30 09:45:22 2017)
3 REPLIES 3
Message 2 of 4
Re: BT SmartHub disconnecting 20 times a day...SIP WAN DOWN
Hi @Gypsyreiver2, welcome to the forum and, post back to update us after the engineer visit.
cheers
John
Message 3 of 4
Hi @Gypsyreiver2,
How did things go with the engineer, were they able to help with the disconnections?
Paddy
Message 4 of 4
Unfortunately not, engineer was due this morning but got the good old email saying that BT had tested the line speed and all was good, fault was closed.
So re-opened fault, engineer due back tomorrow if this visit it not cancelled.
Previous engineer did say a fault on the line 'double tap' but was unable to locate the source....it maybe require a 30 m trench through the garden to lay a new line
