Message 11 of 22
Re: BT Sport App 4K?
Hi Nigel, yes I'm using the same account as set up for my broadband and BT TV but no option for BT Sport Ultimate. Will see if my Sony TV app thinks differently at half time.
Message 12 of 22
@Gashead try deleting the app and re downloading it from the app store just in case it's running an old version that hasn't updated.
Message 13 of 22
@Gashead Are you casting to the Shield using the inbuilt Chromecast or are you accessing BT Sport directly through the Shield App downloaded from the Play Store?
Message 14 of 22
Using the BT TV app. I uninstalled, rebooted and reinstalled and version unchanged
2.18.0 - 1.0.3 27/11/2020
phone is on 8.9.0 so must be a completely different numbering system.
Device checker still tells me my equipment and line speed is capable of 4K and HDR but Account tells me the enigmatic need to upgrade to BT Sport Ultimate and no Ultimate channel available in the guide.
Message 15 of 22
It definitely sounds like an account issue then.  Hopefully one of the mods will be able to help out with it..
Message 16 of 22
Tempted to call 0800 150150 again but when I called yesterday was told there was no 4K support in the Android app.
Message 17 of 22
According to the FAQ's Android app only supports HDR and not 4K HDR..
@DarrenDev should the Nvidia Shield support 4k HDR on BT Sport?
Message 18 of 22
No 4k support in the Android mobile/tablet app, but Android TV supports 4k / HDR. The the device checker says it's an account issue, so it'll be a provisioning error. Send me a DM with your BT ID and I'll take a look this evening.
Message 19 of 22
@Gashead  can you dm @DarrenDev and he'll look into your issue for you 👌
Message 20 of 22
Thanks for hooking me up Nigel, I have done so and will report back if and hopefully when resolved.
