Message 1 of 16
BT Sport App on Andriod TV rotated screen
My screen is now rotated by 90 Degrees and can no longer use remote. Anybody else experiencing this and any suggestions to rectify? I have already tried restarting TV and reinstalling app (Sony Bravia Andriod TV)
15 REPLIES 15
Message 2 of 16
Re: BT Sport App on Andriod TV rotated screen
Is it just the BT Sport app that is rotated? Or everything?
Message 3 of 16
Just BT Sport
Message 4 of 16
All other apps and inputs are as normal
Message 5 of 16
I'm wondering if the correct app has been installed by Google.
Do you see a menu across the top of the screen and a cog in the top right corner? Or do you see just a BT Sport logo at the top, and then 5 tabs shown across the bottom?
(when I say top / bottom, I mean if you tilt your head 90 degrees to match the picture)
Message 6 of 16
Five tabs at the bottom
Message 7 of 16
Ok so it has installed the mobile app on your TV. Did you use the Play Store to install the app? Could you try uninstalling and installing again?
Message 8 of 16
I have alreday tried uninstalling and reinstalling
Message 9 of 16
Have uninstalled, turned tv off and reinstalled. All to no avail. Still rotated in app. Also, have noticed does not appear in usual shortcuts.
Message 10 of 16
Same problem. The app disappeared from the home screen on my Sony TV, but appeared under app listing. Loaded like a mobile phone app (portrait) and crashed. Reinstalled but still screwed. Rebooted TV, still screwed. Looks like a phone app trying to install on a TV. Has there been a **bleep**-up with an update?
