Message 11 of 16
Re: BT Sport App on Andriod TV rotated screen
If you look at the description of the app in the Playstore it states it is for phone and tablet lol. No wonder it's broken. Hopefully they are going to sort this PDQ.
Message 12 of 16
The same listing in the Google Play Store is used for both the mobile and TV versions of the app. Both app versions get uploaded, and Google decides which version of the app to install depending on the device capabilities.
For some reason that I've yet to work out, Google has decided that Android TVs are now capable of running the mobile app.
I'm currently in the process of releasing a new version of the Android TV app to the Play Store that will correct this. It can take Google a few hours to approve/release updates - I'll update here as soon as I've received confirmation.
Message 13 of 16
The update has now been approved, and should appear in the Play Store in the next few minutes. Sorry for the inconvenience.
Message 14 of 16
Yep, it's working now for me, thanks
Message 15 of 16
Working for me now, thanks
Message 16 of 16
Working now. Thanks.
