Message 1 of 2
BT Sport app
Hi I can’t log in to my bt sport app with my usual my bt user name and password. I have been trying for ages
1 REPLY 1
Message 2 of 2
Re: BT Sport app
If you're seeing error ID001 then you're entering your credentials incorrectly.
If you're seeing ID003 then we can't find an active subscription on your BT ID - check www.bt.com/help/id003 for details on how to check your subscription.
If you're seeing ID006 then your account is locked out. Log into www.bt.com/mybt and follow the prompts to reset your password.
