Message 1 of 13
BT Tv Box
Hi
I have an annoying noise that comes each time I change channels. BT says there is nothing wrong with their box after running lengthy diagnostic tests and also sending a replacement box. Still having the same issue. BT has proposed that noise may be due to some interference with other nearby media players like TV, Fire Tv or PS4, etc.
Now I cannot change my other devices because of the reason noise comes FROM Bt Tv box.
How to get rid of this issue ? Really feel frustrated by BT and would love to leave them forever and ASAP provided they don’t kill me with hefty penalty charges.
Any solution ?
Regards
Dr Shah
12 REPLIES 12
Message 2 of 13
Re: BT Tv Box
Can you describe the noise?
There is a high-pitch noise that many Panasonic tvs and a few others makes suffer.
@Drskhanwrote:
Hi
Any solution ?
Regards
Dr Shah
Message 3 of 13
Re: BT Tv Box
Yes it’s a high pitched noise just like some blitz in milliseconds but high pitched.
BT says there is no fault at their end ? Whereas I consider its BTs fault as I am having an issue with one of their hardware devices aka BT Tv box. Now I cannot change my Tv just for this reason.
Any solution ?
Message 4 of 13
Re: BT Tv Box
Is the tv a Panasonic?  If it is the fault I'm thinking of then it is the tv.
That fault occurs when changing channels and triggering a change from PCM to DD or vice versa. It occurs on Freeview/Youview boxes, Sky boxes and VirginMedia box.
The tv emits a high-pitch noise for a short time when there is actually no sound output.
Panasonic will say it is the fault of the set-top-box - whatever make it is.  The fault is actually with a chip which is used by different tv manufacturers but mainly Panasonic.
The way around it is to put the audio via an amplifier and by-pass the tv.
Without more details I can't say if we are talking the same issue.
Any solution ?
Message 5 of 13
Re: BT Tv Box
Thanks for this but mine is Hitachi
I have been using the same Tv last 4 Yrs. Never had such issue Sky or other service set up boxes. It’s just with BT TV box when I switched over in Jan 2021 I am having these issues.
Message 6 of 13
Re: BT Tv Box
It is other makes too - some models work and some don't.
Try changing the audio output setting on the BT box.
Message 7 of 13
Re: BT Tv Box
Thanks can you share the pic of how audio output setting ?
Message 8 of 13
Re: BT Tv Box
No as I no longer have a BT box with that option.
It is in the settings menu under 'picture & sound' (I think).
Message 9 of 13
Re: BT Tv Box
Alright thanks for that you are happy without box!
Guys what’s the most economical manner to leave BT once for all ? I fear I may end up paying hefty amount. Any alternative or way out of this mess ?
We have literally stopped watching BT Tv since last 04 months.
Message 10 of 13
Re: BT Tv Box
I have the new Pro Box which does not change audio format on a channel change.
I route everything through an amplifier which stopped the 'noise' issue as it was being output by the tv.
If it is the same issue - then you will get the issue using Sky and/or VirginMedia.
