Message 1 of 3
BT Virus Protect says product is deactivated
If you get this message from BT Virus Protect saying product is deactivated simply change the computer name and reinstall BT Virus Protect.
I found this advice on this community site. Well done.
Somebody needs to tell BT and Mcafee.
2 REPLIES 2
Message 2 of 3
Re: BT Virus Protect says product is deactivated
Or use another product! Microsoft/Windows Defender spring to mind for Windows based computers. Light and effective and free.
Message 3 of 3
Brilliant. Thanks very much. I have spent hours with BT with no success!! This is so simple and I will tell them tomorrow.
Regards NicolTG
