Message 1 of 8
BT Wi-Fi still active after opting out
Hi
I opted-out of BT Wi-Fi some years ago and noticed recently that BT Wi-Fi had been re-activated on my BT Smart Hub. After reading some posts on here, I opted-in to BT Wi-Fi through My BT, waited 7 days and opted-out again. Its now more than 7 days since I opted-out again, but its still showing as active.
What else can I do to get it de-activated?
Thanks.
7 REPLIES 7
Message 2 of 8
Re: BT Wi-Fi still active after opting out
in some cases it can take up to 28 days to deactivate
Message 3 of 8
It's now more than 28 days since I opted out, but my BT Smart Hub is still showing BT Wi-fi as active.
What's the next step? Thanks.
Message 4 of 8
Are the moderators able to help with this issue? Thanks.
Message 5 of 8
I understand your frustration with this and BT should change their T&Cs for the benefit of the consumer.
Anyway, this has worked for me every time after the intervention from the MODs:
  • Go into MyBT and check if Opted in or Opted out. If Opted out then Opt in and wait 24hours minimum.
  • Go back into MyBT and Opt out and after 48 hours check if you have been Opted out.
  •  If still not Opted out, wait further 48 hours.
  •  I have never had to wait 28 days! If you do then MODs need to intervene.
Message 6 of 8
Hi Dippu
Thanks for the reply. I followed all of the steps you have outlined before my first post above.
Its now 37 days since I last opted out of BT Wi-fi. The Manage BT Wi-fi page on My BT has shown me as opted-out for all of that time. However, my BT Home Hub is still showing BT Wi-fi Status as Active.
Are the mods able to force an update to the BT Home Hub settings?
Message 7 of 8
I have tried multiple times to opt-out of BT Wi-Fi without success.
Each time I have opted-in for 1-7 days and then opted-out. Each time I have waited for >28 days before trying again. My BT Smart Hub still shows BT Wi-Fi Status: Active.
I don't think my BT Smart Hub is associated with my BT account. Is this something that the mods can check?
Thanks.
Message 8 of 8
Hi @david644803  sorry that this keeps happening and you can't get opted out. I've sent you a Private Message with details on contacting the Mod team and we'll be happy to help you get this fixed.
cheers
John
