Message 1 of 10
BT box office app not allowing me to sign in
I’ve just download the BT sport box office app and registered an account. When I go to sign in it says ‘this application is currently unavailable in your area’, how do I sort this?
9 REPLIES 9
Message 2 of 10
Re: BT box office app not allowing me to sign in
Where abouts in the UK are you?
Message 3 of 10
Hi, @Charlie1189 thanks for posting and welcome to the community. The app is only available from within the UK if you have a VPN or other type of software on your device that masks your IP address you'll need to disable it before opening the app.
Cheers
Neil
Message 4 of 10
Hi Neil, thanks for your reply. What do I need to disable before opening the app?
Message 5 of 10
West London
Message 6 of 10
Hi @Charlie1189 do you have a VPN (virtual private network) on your device? If you do then you'll need to turn it off to use the app.
Neil
Message 7 of 10
No I don’t which is why I don’t understand why I’m getting this problem
Message 8 of 10
Go to www.whatismyip.com on your device - what country does it say you're in?
Message 9 of 10
London, England
Message 10 of 10
Are you able to try any other network? E.g. over mobile data? If not, reboot your router to get a new IP address and try again.
