Message 1 of 13
BT cloud will no longer work
what can I do and how- BT cloud will no longer work with my IOS 10.11.6 and I can't upgrade old mac
12 REPLIES 12
Message 2 of 13
Re: BT cloud will no longer work
Good Morning,
You are not alone.
Found on another thread.
You can download the previous version of BT Cloud here - https://btcloud.bt.com/web/app/share/invite/IQNh1iNKpb
Regards
Chris
Message 3 of 13
Thank you Chris
Message 4 of 13
Hi, Im having the same problem. Just spent 30 mins waiting for customer services who said there is nothing they can do and won't advise at all. This link doesn't work - do you have another one? When I download and click nothing happens
Message 5 of 13
Hi @ANG2020 and thanks for posting.
Sorry you're having problems with the cloud. What browser are you using? I've tried the link on chrome and can access it.
Cheers
David
Message 6 of 13
Ahhh ok, Ill try on chrome. I used Safari.
Is this something we should all complain to BT about - surely they need to do a fix?
Message 7 of 13
Sorry Im not very good with this. I can download it but it doesn't do anything when I click on it . Im using Mac OS Sierra 10.12.6.
The cloud worked perfectly before I downloaded the updates
Message 8 of 13
Hi @CD179,
Can you help @ANG2020 with your link?
Cheers
David
Message 9 of 13
Message 10 of 13
