Message 1 of 3
BT cordless phone
Hi
Can anyone please advise.  When using the BT4600 it normally bleeps when the handset is inserted into the base.  Today this bleep has suddenly stopped & we also now have no ring tone for incoming calls.  I've tried following the manual: Settings/ sounds etc. to ensure ringer is on & set to max but it's still not made any difference. Does anyone have any ideas?  Thank you. Ken
2 REPLIES 2
Message 2 of 3
Re: BT cordless phone
Hi @KenDen. Have you tried rebooting the phone by taking the batteries out?
Message 3 of 3
Hi
Thank you.  I don't see any way of removing batteries but I turned off both base units at the mains to see if & that re-boots it. Turned back on after a few minutes. Had to reset time & date.   That seems to have solved the problem. Thank you Ken
