Message 1 of 2
BT extender 300
My extender(300) has stop working , you can contact but no WiFi . I have tried to reset and reconnect using method 1 and 2 but they both fail . I just get a flashing slow red light . The router seems to think it’s connected and the WPS switches off and the extender flashes orange then it goes back to flashing red . Method 2 just times out
1 REPLY 1
Message 2 of 2
Re: BT extender 300
Hi @Rosi1
Welcome and thanks for your post!
I'm sorry for the problems you're having with  your BT Extender 300.  Your best bet with this is to have a word with product support for that device.  You'll find their contact details on the following --> User Guide <--
Cheers,
Robbie
