Message 1 of 2
BTHub6 WiFi directional coverage
Does anyone know if the WiFi signal from a BTHub6 is radiated all round or does it emit predominantly in one direction or another?  I experience a WiFi dead-spot in one part of my house where I have put my WiFi printer.  If I knew which way to align the Hub for the best signal towards the printer, it might be enough to solve the problem without having to buy a WiFi range extender.
Peter M
1 REPLY 1
Message 2 of 2
Re: BTHub6 WiFi directional coverage
Hi @PeterMartinez the hubs wifi isn't directional. It's likely the number of walls it has to go through or the building materials used that is preventing it from reaching the dead spot.
Neil
