Message 1 of 2
Baby monitor 6000
I have a baby monitor 6000, I have a spare camera I want to set up so I can use one monitor with two cameras. I can see there is an option to add camera in menu but when I try nothing happens even when both cameras are plugged in and on. It just shows my original camera.
1 REPLY 1
Message 2 of 2
Re: Baby monitor 6000
Hi @Phendo  and welcome to the community.
Sorry you're having problems linking the second camera. You might want to try the relink process -
How do I re-link my camera?
To re-link the Baby unit camera to the Parent unit camera:
  1. Press MENU when the Parent unit is in camera viewing mode
  2. Select the Camera + Icon
  3. Press the + UP / - DOWN button to select a number to assign it to and confirm with OK
  4. Hold the LINK button on the rear of the camera until the unit beeps and the image from the camera appears on the screen
If that doesn't work then you can contact the product support desk on
 0808 100 6554
Monday to Friday 9.00am to 5.30pm
If it's out of warranty call 0800 980 8999.
Cheers
David
