Message 1 of 17
Banded VDSL Not Resolving
Hi All
I'm interested in some input re: situation on my FTTC line.
When installed line was stable at 3db SNR and 39Mbps - this lasted 3 months.
Then something occurred and the line starting dropping almost at 14 day intervals.
 Going from
Feb 15th:
DSL Link Up: Down Rate=39999kbps, Up Rate=6536kbps; SNR Margin Down=3.4dB, Up=6.0dB
Oct 11th:
DSL Link Up: Down Rate=22399kbps, Up Rate=5844kbps; SNR Margin Down=10.9dB, Up=6.1dB
During this time the BT hub would appear to lose connection almost daily in the late evening.
An engineer (BT - not openreach) visited and changed the socket in Aug, not much changed.
In september I replaced the modem with an HG612 to check stats and it was quite clear there was REIN interference - SNRM was jumping all over the place (see first pic).
I identified some powerline ethernet adaptors as a possible cause and removed them and the line settled.
An Open Reach engineer in November while fitting a new broadband line identified water in some of the OR junctions and cleaned it out - as this was not on my line, no line reset performed.
Since then the line has been rock solid with little to no SNRM fluctuation, ES per day less than 2 (0.06/hr) however the line remains banded at 25,000 kbps.
I get the feeling DLM has acted over the last year in response to noise and possible water in the circuit.
However now things appear to have cleared and stats have been stable for a while I'd like to get this banding removed and go back to 3DB SNRM and the speed the line should achieve.
Line stats prior to fix.
Line stats with unstable SNRLine stats with unstable SNR
Stats currently.
Line stats nowLine stats now
I did message @JohnC2 privately, and thanks for your response John - I'm posting this for feedback.
Ideally I'd like a line reset to allow the line to settle back to it's state last year now that things are stable.
Cheers
16 REPLIES 16
Message 2 of 17
Re: Banded VDSL Not Resolving
welcome to the BT community forum where customers help customers and only BT employees are the forum mods
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
The 14 day resets are a common problem but are more inconvenient than cause a connection problem as connection normally recovers immediately at same speed and noise margin  however the daily resets are more likely to have caused your drop in speed and increase in noise margin. The socket change didn't seem to help - there are no BT engineers  just openreach or a sub contractor
your stats show connection time is only 1 day so are you still dropping connection as you need a stable connection for a few weeks before banding is likely to start to remove
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 17
Hi yes tried the quiet line, all clear.
The connection has been stable for a while, but the night before last the line re-synced and interleaving went from 4 -> 16.
This despite next to no errors for many days and SNR very stable.
Does anyone have any insight into why a DLM resync would occur and increase interleaving (and SNRM from 9 to 10.4 ) with a very stable line (less than 2 ES / day).
Thx
Message 4 of 17
It appears the DLM is registering errors which not shown by router but sufficient that it caused a reset and an increase in noise margin and interleaving depth to try and improve your line. Until the line problem is solved you are not getting out of banding and if drop outs continue then banding may get worse
Message 5 of 17
The CAB I'm connected applies any changes at around 3-4AM
The 3.59 AM resync I saw was pretty clearly DLM initiated, but if my connection is showing stable SNRM, sub 2 ES, low FEC  - then I'm interested in what the DLM can see that my modem can't ?
Does the DLM not pull error data from the modem throughout the day and apply changes on this basis at around 3-4am?
If anything based on the line stats the status should be green and the DLM should be working to lower SNRM / remove banding / increase speed - not the opposite.
Again, thanks for taking the time and your insight appreciated
Message 6 of 17
Mods - this connection has been banded at 25000 for a couple of months now - I don't see the DLM intervening to fix it (from what I've read it could be many months if it all) - it's just a little over half of what the line has been stable at previously and right at the bottom of the acceptable range.
A fault was raised in September / Oct and I was explicitly told by BT Phone support - 'we're sending an expert trouble shooter'
The engineer appointment came and went with no visit.
When I queried BT the response was "The engineer came but just visited the CAB" - which I find really very unlikely as I've never had an OR engineer investigate an issue and not even check the ingress to the property.
Would really appreciate an assist on this.
Cheers
Message 7 of 17
Also - I was told by BT support that they couldn't help further me unless I was using their Home Hub 5 - which imo is unreliable and I have had 2 units fail on me before, both times killing the connection and requiring an OR visit to reset the line.
Ludicrously, BT support also said that they would send an extra Whole Home Wifi disc which "would help the problem".
- of a banded connection? Really ?
Now either they have zero idea how their own product works, or they are pushing the problem away. How is it more cost effective to send a whole home disc rather than just reset the flipping line. I'm baffled.
In any case I'm tired of the lies and disinformation. I know the mods here are the only way this is going to resolve.
Message 8 of 17
the problem is there is no point in a DLM reset if you are still dropping connection on a regular basis as in no time the DLM would have you back in banding as line appears unstable.
if you can get engineer to solve the connection drops then engineer request a DLM reset having fixed the unstable connection would be best way forward
Message 9 of 17
Hi @imjolly  - The only resync that has occurred has been a DLM initiated resync, has occurred once with the only noticeable change being an increase in interleaving.
Line stats and errors are and were rock solid.
No random drops at all - which implies the line is stable.
I haven't heard anything convincing re why the DLM would resync on a stable line with so few errors, the only way to find out what is going on is for someone with access to the line to take a look.
From what I've read on this site, if a line has interference problems or a fault over many months, it is unlikely DLM will act to remove banding etc without a reset  - or if it does it will take a very long time.
You seem to be saying that a DLM resync at 3am implies an unstable line, and this needs to be fixed somehow before a reset ?
How certain are you of this, as there's no way this is taken seriously as a fault by BT phone support and there's not much else I can do having removed any possibility of interference and monitored stats for 8 weeks +
Cheers
Message 10 of 17
Hi @vivoid  sorry that you haven't been able to get this resolved. I've sent you a Private Message with details on how to contact the Mod team and we'll be happy to take a look at your connection for you.
cheers
John
