Message 1 of 4
Banded?
Hi all
just a general question really. Interested to know if my broadband has been limited to 35mb.
I’ve noticed overtime that my downstream rate stays rock solid on 34999kbps and the max rate fluctuates up and down.  The upstream rates both move.
I know I can’t achieve much faster speeds, but just interested as to why it is that figure.
BTW, I get the same thing using my smarthub 2 as well.
3 REPLIES 3
Message 2 of 4
Re: Banded?
With constantly staying at 34999 I would say that it is banded but luckily you are just below max attainable
Message 3 of 4
Re: Banded?
@imjolly
thanks. How easy is it to get the banding removed, and is it really worth the hassle 😀
Message 4 of 4
Re: Banded?
as you are probably well within your expected speed range and just short of your attainable I doubt BT will do anything.  you would need engineer out for a fault and if found and fixed then you could ask engineer to reset DLM
