Message 1 of 9
Black Wi-fi disc
Hi, I added a Wi-fi disc to my network a while back and had no issues until recently where the disc had a constant red light. I reset to factory settings an paired with my home hub and all worked fine again. I have read about just resetting my home hub and have now had to do this maybe 5 times in the last few weeks as the Wi-fi disc will have a constant red light, but as soon as I reset my hub I will turn blue and start working again. Any ideas on how to fix this issue?
Tags (1)
8 REPLIES 8
Message 2 of 9
Re: Black Wi-fi disc
Turn off Smart setup; What is Smart Setup on the BT Hub? How can I turn it on and off? | BT Help
If not that then check that the hub is operating in wireless mode 1
Message 3 of 9
I have turned smart set up off now and the hub was already set to wireless mode 1. Will have to leave it a few days to see if this helps, thanks
Message 4 of 9
So the red light has returned to my disc this morning again, anything else I can try?
Message 5 of 9
Have you tried using the MyBT app to help you find the optimum position for the disc?
Tap on the three dots in the bottom right hand corner to access a side bar
Message 6 of 9
Yeah it’s connection to main hub is excellent
Message 7 of 9
Are there any doors between the hub and the disc which might affect the signal when closed?
If not then it sounds like you might have a faulty disc
Message 8 of 9
There is a few doors but makes no difference in signal Strength whether there open or closed. Yeah I’m thinking faulty disc, is there anyway of updating the disc or the likes?
Message 9 of 9
No way implementing a manual update to my knowledge. It sounds like you need to ring 0800 800 150 and report it, unless a mod picks up on this thread and offers help
