Message 1 of 7
Boardband not working
Hi all, have you got any problems with BT boardband in IG10 area?  Thanks.
6 REPLIES 6
Message 2 of 7
Re: Boardband not working
Visit https://my.bt.com/consumerFaultTracking/public/faults/tracking.do?pageId=31
Also make sure you have dial tone on your phone.
Message 3 of 7
Hello Keith,
I have dail tone and checked that at BT level everything was fine and the bill was paid.    My BT hub box just kept flashing orange light all of a sudden.... i have now switched it off for a bit and see if that helps.
Message 4 of 7
Dial 17070 and make sure the number read back, matches your phone number.
Message 5 of 7
Yep. Checked. Right number.
May i ask what is the usual cause of sudden loss of connectivity. I have touched the box nor the cable at all!! Very annoying
Message 6 of 7
It could be anything, but its worth checking your own internal connections by trying the test socket which is located on your master phone socket.
Message 7 of 7
I managed to speak to BT and need to wait for a new box and engineering to come.  While I am waiting, how good do you think a pay as you go dongle will be as a temporary fix for connecting a desktop to wifi?  Thanks
