Message 11 of 13
Re: Broadband Current Service
Which version of home hub do you have?
Message 12 of 13
I wondered if you would ask that question: It is Home Hub 3.
And, re your previous reply re IP address; check my response above yours. That was the IP address I used to get the data.
Message 13 of 13
In which case you must still be using an Openreach modem along with the hub which is where the line stats will be held. They will not be accessible unless you have hacked the modem to unlock it.
I suggest you ask customer services to send you a Smart Hub 2 to replace your modem and hub.
