Message 1 of 24
Broadband capping
HI. I have recently joined BT fttp. After a good start I seem to be capped at 10Mb/s download sync speed as past few weeks. Before  that the router had been consistently  been between 12 and 14 Mbps.  I have all the information here from my Samknows box for the last 3 years
23 REPLIES 23
Message 2 of 24
Re: Broadband capping
Hi @Pyebald welcome to the community and thanks for posting.
Can you post your Home Hub router stats and we'll take a look? You'll get them by entering 192.168.1.254 in your browser, go to advanced settings then technical log information.
Neil
Message 3 of 24
I have the technical log downloaded but I don't know how to send it
Message 4 of 24
Take a screenshot of the information page and post it using the camera icon.
Message 5 of 24
Message 6 of 24
Hi @Pyebald
Many thanks for posting the stats. They show you are on FTTC and not FTTP. I can't see anything wrong based on the max attainable and noise margin stats and there doesn't appear to be much room for improvement.
Can you post the results from the wholesale availability checker? Make sure you remove your telephone number before posting the screenshot.
Neil
Message 7 of 24
I'm interested to know how, if you have only just joined, you can have SamKnows stats going back 3 yrs.
Message 8 of 24
 This is from the last 6 months' download speed. I was with Plusnet before BT and the speed was always better than what I am getting now.  I think the reduced speed may to do with a Lightning strike we had about 3 weeks ago. It took out my router  and various other network-connected devices
Message 9 of 24
can you enter phone number and post results - see what the estimated range for your line actually is   https://www.broadbandchecker.btwholesale.com/#/ADSL
can you leave exchange and cab number but delete phone number
Message 10 of 24
