Message 1 of 6
Broadband connectivity
A few months ago, the complex where I live had a fibre optic cable installed.  Since then I've had major broadband problems.  I lose the connection at about 11pm at night and can only connect again at 7am.
Can anyone suggest what might be going on here?
5 REPLIES 5
Message 2 of 6
Re: Broadband connectivity
@AngelaMacleod_99
Please can you confirm who provides your broadband connection, and is it connected to the new fibre optic cable?
Message 3 of 6
vODAFONE IS MY NETWORK PROVIDER.  bt oPENrEACH HAS BEEN DOING A LOT OF WORK WITH CABLES IN THE AREA AND THE PROBLEM ONLY BEGAN WHEN THE CABLE WAS INSTALLED.
Message 4 of 6
How would I know if Vodafone was connected to the cable? Should they be?
Message 5 of 6
@AngelaMacleod_99
This is just a BT Retail customer forum, so nobody here would be able to help with this. Openreach are a separate company and there is no help available here.
Please ask on the Vodaphone user forum.
https://forum.vodafone.co.uk/
Message 6 of 6
If your broadband is provided by vodafone then you need to post on Vodafone forum  this forum is for BT RETAIL  customers and there is no link from here to openreach
