Message 1 of 8
Broadband issues [Full Detail, looking for help]
Hello.
So today, i was in a ZOOM video where my randomly my connection started to drop, I had to swap to using my phones mobile data to connect to the call to resume, however after the meeting my collection has dropped altogether.
I have factory reset my BT Home hub 6 to try and resolve this issue however, no luck, I've ran an Agent run an Copper Line test and a VDSL line test and both came back as Passed, however on the hub it is showing a blue light, but when trying to visit sites, I get timeout error, I've tested this on my desktop(hard wired), my MacBook pro(wireless/tested ethernet) and I get the same results, I was told We will be sending you a new BT Home hub to test, I said ok and called ended.
However, after digging around as I knew I had a spare bt home hub 6 that was never opened from the box, I plugged this into my VDSL Cable and got the same issue. So I have phoned again and now book and engineer for a week today.. but I need to be ok the internet to beable to do my work.. As Technical support Engineer i need to be online to beable to supprt end-users with there desktop issues.
When checking my outbound speeds, it is reporting a connection of around 30-40KB/s, when checking on the bt home hub 6 page, it is reporting
VDSL Download sync 32.5mb/s.
VDSL upload sync 7.54mb/s.
However no sites are loading, I have run a ping test for nearly 2 hours to google which resulted in a 98% packet loss over 7684 were sent but never returned.
Is there anything else I can try on my end, I only have the one Mastersocket 5c in my house, I've tested with the port and with the "Testing port" and still no luck.
EDIT: We have no landline connected to the Line... the Line is only in for the broadband so it can't be a notice issue, I've also had an SNR test ran and passed also.
7 REPLIES 7
Message 2 of 8
Re: Broadband issues [Full Detail, looking for help]
Have you turned off smart setup in hub manager as that often causes problem
as you have hh6 which firmware is it on?
Message 3 of 8
Hello Imjolly,
Thanks for the prompt response really appreciate it.
The smart setup has been disabled that was step one of troubleshooting.
Below is some information which hopefully is useful?
  • Product name:
    BT Hub 6A
  • Serial number:
    +084316+NQ64325024
  • Firmware version:
    SG4B1000E020
  • Firmware updated:
    24-Mar-2020
  • Board version:
    1.0
  • Gui version:
    1.115.0
DSL uptime:
0 Days, 1 Hour 24 Minutes 21 Seconds
  • Data rate:
    7.32 Mbps / 31.49 Mbps
  • Maximum data rate:
    7420 / 37991
  • Noise margin:
    6.1 dB / 6.4 dB
  • Line attenuation:
    33.7 dB
  • Signal attenuation:
    33.5 dB / 33.7 dB
  • VPI / VCI:
    0/38
  • Modulation:
    G_993_2_ANNEX_B
  • Latency type:
    Fast Path
  • Data sent / received:
    6 MB Uploaded / 17 MB Downloaded
  • Broadband username:
  • BT Wi-fi:
    Active
  • 2.4 GHz wireless network name:
    BTHub6
  • 2.4 GHz wireless channel:
    Smart (Channel 6)
  • 5 GHz wireless network name:
    BTHub6-5
  • 5 GHz wireless channel:
    Smart (Channel 36)
  • Wireless security:
    WPA2 (Recommended)
  • Wireless mode:
    Mode 1
  • Firewall:
    On
  • MAC address:
    24:20:C7:45:78:9F
  • Software variant:
  • Boot loader:
    7.33.1
Message 4 of 8
If you use search facility for Hh6 firmware you will find customers with same hub and firmware as you are having problems
Message 5 of 8
Hello, so looking it appears it has something to do with an error on the firmware or BT's way of pushing every to get the new smart hub 2?
Message 6 of 8
just adding to my comment, currently, I'm not able to access the internet at all using my broadband I am having to use my hotspot
Message 7 of 8
Hello,
Is there anything I can do as I do not have an internet connection, I'm running on less then 40kb/s a second which is unusable, I can't work from home and am not using my personal data to set up a hotspot. .. Was working fine and then all of a sudden stopped. @imjolly ??
Message 8 of 8
Hi,
Where are you getting the 40  kbps speed reported from ? Is that using a Wifi connection ?
Not so much of an expert, but something that has helped me in the past , I have noticed on occasion, my HH6 Wifi connections become so slow that it is unusable.  A printer in my network stop working completely. This happened probably about say once in 3 months but rare. However, initially i used to reboot the router from the HH6 menu, but lately I discovered that turning off the Wifi  from the menu , save it and turning it on and save it helps too. Mind you, during this time when I have issue with Wifi, my cabled connections were working well. I am not sure if this is your scenario too
