Message 1 of 9
Broadband keeps dropping out but BT Troubleshooter shows no faults...
Evening, here's a brain teaser for you (at least, it feels that way to me!)
Short story: Broadband keeps dropping out, but the BT Troubleshooter shows no faults, so it won't let me book an engineer.
Long version: I'm 1.3KM from my roadside cab. This cab is missing one of it's doors and is usually full of leaves, rain and a big mess of cables...
I was on a FTTC connection (12Mbps down, 1Mbps up) but the stability was very poor and I couldn't connect to video conferincing calls or Teamviewer, so I downgraded to the standard copper connection. This has proved to be slightly slower, but a lot more stable over the distance. I now get 8Mbps download, and 0.54Mbps upload, it's been slow but I can just about hold a call or a Teamviewer session (but not both!).
Over the past few weeks my connection started dropping out for a couple of mins once or twice a day. The HH5 lights cycle through red and orange and it finally connects up again without help. It's getting worse and worse now, and it now drops out for 5-20 mins at a time, and this occurs circa 10 times per day.
Just to add to the mix, I'm now working from home full time and doing volenteer IT Support for a local school, and have two children at online school...
The incoming line goes to the master socket only, there's no extensions and no internal phone wiring. Master socket is right by the door, and is a Master Socket 5C that was replaced 8 months ago. I've plugged into the test point but it makes no difference. I've rebooted the router, left it off overnight, factory reset it. My laptop is cabled straight in with a Cat6 lead.
When I run the BT Troubleshooter it shows as no fault, even if the HH5 is flashing red for the full duration of the test. So, I can't book an engineer test and my phonecalls go unanswered (TBH after an hour on hold I gave up).
This is truly the long version!
What can be done?
8 REPLIES 8
Message 2 of 9
Re: Broadband keeps dropping out but BT Troubleshooter shows no faults...
Just adding in router stats in case it helps:
00:06:12, 07 Jan.             ( 2210.570000) Admin login successful by 192.168.1.81 on HTTP
00:05:25, 07 Jan.             ( 2164.200000) New GUI session from IP 192.168.1.81
00:05:09, 07 Jan.             ( 2148.290000) Lease for IP 192.168.1.81 renewed by host DESKTOP-​45TAPMV (MAC 54:8d:5a:97:38:9e). Lease duration: 1440 min
00:05:09, 07 Jan.             ( 2148.280000) Device connected: Hostname: DESKTOP-​45TAPMV IP: 192.168.1.81 MAC: 54:8d:5a:97:38:9e Lease time: 1440 min. Link rate: 866.6 Mbps
00:05:09, 07 Jan.             ( 2148.190000) Lease requested
00:05:09, 07 Jan.             ath10: STA 54:8d:5a:97:38:9e IEEE 802.11: Client associated
23:57:14, 06 Jan.             IN: BLOCK [16] Remote administration (TCP [198.143.155.122]:37468-​>[86.135.65.227]:8080 on ppp0)
23:52:30, 06 Jan.             IN: BLOCK [16] Remote administration (TCP [142.114.98.22]:51627-​>[86.135.65.227]:80 on ppp0)
23:51:54, 06 Jan.             IN: BLOCK [16] Remote administration (TCP [93.174.93.218]:59374-​>[86.135.65.227]:8080 on ppp0)
23:48:16, 06 Jan.             IN: BLOCK [16] Remote administration (TCP [27.102.134.114]:56246-​>[86.135.65.227]:80 on ppp0)
23:47:59, 06 Jan.             IN: BLOCK [16] Remote administration (TCP [112.91.109.103]:51199-​>[86.135.65.227]:22 on ppp0)
23:37:59, 06 Jan.             IN: BLOCK [16] Remote administration (TCP [164.68.112.178]:54405-​>[86.135.65.227]:22 on ppp0)
23:34:14, 06 Jan.             IN: BLOCK [15] Default policy (TCP [195.54.161.122]:54362-​>[86.135.65.227]:4400 on ppp0)
23:34:12, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.52]:57155-​>[86.135.65.227]:44854 on ppp0)
23:34:07, 06 Jan.             IN: BLOCK [15] Default policy (TCP [195.54.161.122]:54362-​>[86.135.65.227]:8800 on ppp0)
23:34:04, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.179]:57879-​>[86.135.65.227]:52073 on ppp0)
23:33:58, 06 Jan.             IN: BLOCK [15] Default policy (TCP [78.128.113.42]:50239-​>[86.135.65.227]:8146 on ppp0)
23:33:39, 06 Jan.             BLOCKED 1 more packets (because of Default policy)
23:33:38, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.24]:58678-​>[86.135.65.227]:21104 on ppp0)
23:33:32, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.171]:43692-​>[86.135.65.227]:60116 on ppp0)
23:33:30, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.80]:57356-​>[86.135.65.227]:49299 on ppp0)
23:33:29, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.80]:57356-​>[86.135.65.227]:48091 on ppp0)
23:33:14, 06 Jan.             IN: BLOCK [15] Default policy (TCP [167.248.133.84]:39316-​>[86.135.65.227]:46000 on ppp0)
23:33:07, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.179]:57879-​>[86.135.65.227]:51033 on ppp0)
23:33:04, 06 Jan.             ( 222.770000) CWMP: session closed due to error: Timeout
23:33:04, 06 Jan.             IN: BLOCK [15] Default policy (TCP [199.117.180.44]:443-​>[86.135.65.227]:43507 on ppp0)
23:33:03, 06 Jan.             IN: BLOCK [15] Default policy (TCP [194.26.25.13]:49669-​>[86.135.65.227]:3577 on ppp0)
23:33:02, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.12]:52860-​>[86.135.65.227]:52815 on ppp0)
23:33:00, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.81]:41966-​>[86.135.65.227]:7078 on ppp0)
23:32:59, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.122]:53785-​>[86.135.65.227]:22144 on ppp0)
23:32:55, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.125.65.61]:40140-​>[86.135.65.227]:1400 on ppp0)
23:32:54, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.174]:57974-​>[86.135.65.227]:58308 on ppp0)
23:32:50, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.121]:57202-​>[86.135.65.227]:46363 on ppp0)
23:32:34, 06 Jan.             ( 192.440000) CWMP: Set Parameter by TR069 failure 9007: Unable to activate 5GHz capability when 2.4GHz is inactive
23:32:33, 06 Jan.             ( 191.920000) CWMP: HTTP authentication success from https://pbthdm.bt.mo
23:32:29, 06 Jan.             ( 188.130000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:32:29, 06 Jan.             ( 188.120000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
23:32:29, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.171]:43692-​>[86.135.65.227]:62465 on ppp0)
23:32:15, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.52]:57155-​>[86.135.65.227]:44882 on ppp0)
23:32:09, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.129.33.176]:57913-​>[86.135.65.227]:54986 on ppp0)
23:32:00, 06 Jan.             BLOCKED 2 more packets (because of Default policy)
23:31:59, 06 Jan.             ( 157.490000) CWMP: session closed due to error: WGET TLS error
23:31:58, 06 Jan.             IN: BLOCK [15] Default policy (TCP [92.63.197.88]:54314-​>[86.135.65.227]:41544 on ppp0)
23:31:57, 06 Jan.             ( 155.350000) NTP synchronization success!
23:31:56, 06 Jan.             IN: BLOCK [15] Default policy (TCP [45.155.205.23]:42073-​>[86.135.65.227]:26066 on ppp0)
23:31:53, 06 Jan.             ( 151.490000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:31:53, 06 Jan.             ( 151.480000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
23:31:52, 06 Jan.             ( 150.310000) NTP synchronization start
23:31:51, 06 Jan.             ( 149.480000) WAN operating mode is ADSL
23:31:51, 06 Jan.             ( 149.480000) Last WAN operating mode was ADSL
23:31:50, 06 Jan.             ( 148.500000) PPP IPCP Receive Configuration ACK
23:31:50, 06 Jan.             ( 148.480000) PPP IPCP Send Configuration Request
23:31:50, 06 Jan.             ( 148.470000) PPP IPCP Receive Configuration NAK
23:31:50, 06 Jan.             ( 148.460000) PPP IPCP Send Configuration ACK
23:31:50, 06 Jan.             ( 148.460000) PPP IPCP Receive Configuration Request
23:31:50, 06 Jan.             ( 148.440000) PPP IPCP Send Configuration Request
23:31:48, 06 Jan.             ( 147.100000) PPPoA is up -​ VPI: 0, VCI: 38 Down Rate=10624Kbps, Up Rate=576Kbps; SNR Margin Down=6.6dB, Up=6.0dB
23:31:48, 06 Jan.             ( 147.090000) CHAP authentication successful
23:31:48, 06 Jan.             ( 146.870000) CHAP Receive Challenge
23:31:48, 06 Jan.             ( 146.870000) Starting CHAP authentication with peer
23:31:48, 06 Jan.             ( 146.870000) PPP LCP Receive Configuration ACK
23:31:48, 06 Jan.             ( 146.840000) PPP LCP Send Configuration Request
23:31:48, 06 Jan.             ( 146.840000) PPP LCP Receive Configuration Reject
23:31:48, 06 Jan.             ( 146.840000) PPP LCP Send Configuration ACK
23:31:48, 06 Jan.             ( 146.840000) PPP LCP Receive Configuration Request
23:31:48, 06 Jan.             ( 146.760000) PPP LCP Send Configuration Request
23:31:43, 06 Jan.             ( 141.830000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=10624Kbps, Up Rate=576Kbps; SNR Margin Down=6.0dB, Up=6.0dB
23:31:43, 06 Jan.             ( 141.830000) ATM over DSL is up
23:30:58, 06 Jan.             ( 96.930000) CWMP: Initializing transaction for event code 4 VALUE CHANGE
23:30:52, 06 Jan.             ( 90.400000) CWMP: session closed due to error: Could not resolve host
23:30:49, 06 Jan.             ( 87.680000) ATM over DSL is down after 0 minutes uptime
23:30:48, 06 Jan.             ( 86.500000) ETHoA is down after 0 minutes uptime
23:30:45, 06 Jan.             ( 83.400000) ETHoA is up -​ VPI: 0, VCI: 35 Down Rate=0Kbps, Up Rate=0Kbps; SNR Margin Down=0.0dB, Up=0.0dB
23:30:45, 06 Jan.             ( 83.400000) ATM over DSL is up
23:30:40, 06 Jan.             ( 79.230000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:30:40, 06 Jan.             ( 79.210000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
23:30:11, 06 Jan.             ( 49.770000) Lease for IP 192.168.1.64 renewed by host BRW4023439CE04C (MAC 40:23:43:9c:e0:4c). Lease duration: 1440 min
23:30:11, 06 Jan.             ( 49.770000) Device connected: Hostname: BRW4023439CE04C IP: 192.168.1.64 MAC: 40:23:43:9c:e0:4c Lease time: 1440 min. Link rate: 52.0 Mbps
23:30:11, 06 Jan.             ( 49.700000) Lease requested
23:30:10, 06 Jan.             ( 48.440000) CWMP: session closed due to error: Could not resolve host
23:30:10, 06 Jan.             ath00: STA 40:23:43:9c:e0:4c IEEE 802.11: Client associated
23:30:05, 06 Jan.             STP Alert: Port eth0 leaving blocking state.
23:30:01, 06 Jan.             ( 40.210000) CWMP: Server URL: https://pbthdm.bt.mo; Connecting as user: ACS username
23:30:01, 06 Jan.             ( 40.200000) CWMP: Session start now. Event code(s): '1 BOOT,4 VALUE CHANGE'
23:30:01, 06 Jan.             ( 39.530000) CWMP: Initializing transaction for event code 1 BOOT
23:29:59, 06 Jan.             ( 37.970000) WiFi auto selected channel 48
23:29:59, 06 Jan.             ( 37.970000) 36-​94::40-​93::44-​93::48-​93::52-​91::56-​92::60-​92::64-​91::100-​91::104-​93::108-​94::112-​94::116-​95::120-​96::124-​97::128-​97
23:29:59, 06 Jan.             ( 37.960000) 5 GHz Wireless: Rescan, Reason: 'Power-​up'
23:29:59, 06 Jan.             ( 37.960000) WiFi auto selected channel 11
23:29:59, 06 Jan.             ( 37.960000) 1-​96::2-​96::3-​96::4-​96::5-​96::6-​97::7-​98::8-​99::9-​98::10-​98::11-​98::12-​97::13-​98
23:29:59, 06 Jan.             ( 37.960000) 2.4 GHz Wireless: Rescan, Reason: 'Power-​up'
23:29:58, 06 Jan.             ( 37.160000) WAN Auto-​sensing running.
23:29:53, 06 Jan.             ( 31.840000) System up, firmware version: 4.7.5.1.83.8.264 (Type A)
23:29:50, 06 Jan.             ( 28.890000) WPA2 mode selected
23:29:50, 06 Jan.             ( 28.890000) WPS disabled
23:29:48, 06 Jan.             ( 26.850000) WPA2 mode selected
23:29:48, 06 Jan.             ( 26.850000) WPS disabled
23:29:39, 06 Jan.             ( 18.210000) System start
23:28:54, 06 Jan.             ( 2483.320000) The system is going DOWN for reboot.
23:28:54, 06 Jan.             ( 2483.320000) OpenRG is going for reboot by IPC command
Message 3 of 9
Report this to Openreach
https://www.openreach.com/help-and-support/damage-health-and-safety
As for the broadband fault, how many times have you reported it to BT?
Message 4 of 9
Keith,
Will report the damage to OR, thanks.
I've reported this to BT 8 or 10 times, each time they say that there's no fault (even if the router is down for the entire duration of their tests!)
Message 5 of 9
when you connected to test socket did you check for line noise by dialing 17070 option 2 - should be silent and best with corded phone
Message 6 of 9
Hi @tomatojuice
Welcome to the BT Community and thanks for your post!
I'm sorry that you're experiencing disconnections with your broadband service.  With the lights changing on the Hub that does indicate the broadband itself dropping off and I am disappointed that you've had to contact us so many times and you're no further forward.
You can get in touch with us and we'll give you a hand.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Message 7 of 9
Yes, quiet line test has a slight hum on it, but no crackling. I'll do a few more tests - intermittent faults are the worst to find!
Message 8 of 9
Thanks Robbie. I've just had a call back from BT (hooray!) Fortunately it dropped while we were on the call. The adviser told me that it's showing as a complete drop 51 times yesterday, and 30 times the day before. I've got an engineer booked for Tuesday 12th, fingers crossed it drops out while they are here!
Message 9 of 9
51 times in one day 😮  That's definitely not right!
I'm pleased my colleague has arranged for an engineer to take a look at this for you.  Keep us posted how things go after next Tuesday following the engineer's visit.
Cheers,
Robbie
