Message 1 of 11
Broadband speed
My broadband speed is absolutely appalling - just upgraded to fibre Halo 1 and the highest speed I’ve managed to get is 8 mbps. This cannot be normal - surely something can be done?
B4E1B7C8-C0CD-4DFF-828D-5939C3B94679.jpegthe BT speed checker won’t even run....
10 REPLIES 10
Message 2 of 11
Re: Broadband speed
@Ali-2020
To see what speeds are available to you, please enter your phone number into this form, and display the results here, omitting your phone number.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
Message 3 of 11
Re: Broadband speed
halo is just an add-on benefit and does not increase or decrease connection speed
Message 4 of 11
Re: Broadband speed
Tags (1)
Message 5 of 11
Re: Broadband speed
speed certainly low - quiet line test?
Message 6 of 11
Re: Broadband speed
Probably one wire disconnected on incoming line, or home hub plugged into the wrong place and is being filtered.
Message 7 of 11
Re: Broadband speed
Quiet line test - very faint static.....
Message 8 of 11
Re: Broadband speed
@Keith_Beddoe Thanks. The phone and the hub attach to the same phone socket via a white box connector with DSL472 on it. Could that be the problem?
Message 9 of 11
Re: Broadband speed
What does your master phone socket look like? If its 5 6 or 7, then you must not use a filter. The home hub must plug directly into the broadband socket, and the phone into the phone socket.
Message 10 of 11
Re: Broadband speed
Hi, it’s a 1 or 4 but thanks for your help, they have run some checks and are getting an engineer to do some checks.
