Message 1 of 6
Broadband upgrade
Hi all,
My fibre broadband is due to be upgraded from 76mbps to 500. Just done a speed test and it hasn't upgraded yet. Do I need my bt smart hub plugged in for the upgrade, as I'm currently not using it and using a linksys tri-band ax5300 instead.
5 REPLIES 5
Message 2 of 6
Re: Broadband upgrade
Do you have FTTC and are upgrading to FTTP?
have you had the ONT installed?
Message 3 of 6
I have fttp and the ont for nearly 2 years, I just wanted the speed upgrade but it hasn't happened yet.
Message 4 of 6
When was the upgrade activation date? You don't need to connect the hub for your connection to upgrade
if upgrade date passed then phone FTTP TEAM 08005874787 and ask
Message 5 of 6
Before midnight on 9th September. I figure that would of been this morning but maybe it means tonight 🤔
Message 6 of 6
@thechosen1Midnight always comes after mid -day.
