Message 1 of 7
Broadband
  • My bt Internet keeps cutting out on most devices in my house it was fine for first month but has been getting worse since. I cannot get onto the live chat to speak to anyone
6 REPLIES 6
Message 2 of 7
Re: Broadband
Are your devices connected with just wifi or is it happening to Ethernet connections?
which hub do you have?  Does the lights on the hub change colour?
in order for the forum members to help please can you post the stats from your router (if hub enter 192.168.1.254 in your browser) and if  HH5 then go to troubleshooting then helpdesk and if HH6/SH2 then advanced settings then technical log information .
Have you tried the quiet line test? - dial 17070 option 2 - should hear nothing - best done with a corded phone. if cordless phone you may hear a 'dull hum' which is normal
enter your phone number and post results  remember to delete number   https://www.broadbandchecker.btwholesale.com/#/ADSL
Someone may then be able to offer help/assistance/suggestions to your problem
Message 3 of 7
Re: Broadband
All wireless connection and the light on my hub stays blue. It's a bthub 6
Message 4 of 7
Re: Broadband
Have you turned off smart setup?
have you split the wireless networks as that often helps. Also select the wifi channels manually instead of using auto
Message 5 of 7
Re: Broadband
Not going to lie to you but I have no idea how to do any of what you have just suggested I'm afraid
Message 6 of 7
Re: Broadband
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
https://www.bt.com/help/broadband/fix-a-problem/broadband-and-wi-fi/i-want-to-improve-my-wi-fi/how-d...
These should help
Message 7 of 7
Re: Broadband
I've done these so I will see how that goes. Thanks for your help
