Message 1 of 4
Broadband
My WiFi keeps disconnecting my my sky Q boxes and TV this has happen a various amount of times since the bad weather last week. It’s become a daily occurrence and sometimes I can’t even connect my sky Q box.
3 REPLIES 3
Message 2 of 4
Re: Broadband
have you turned of smart setup
Turn Off smart setup
Try changing the 2.4/5ghz channels in your hub from auto to specific channels and you use either 44 or 48 for the 5ghz network and not 36 which is used by sky q
Message 3 of 4
Re: Broadband
Hello , how do I change the settings in the hub?
Message 4 of 4
Re: Broadband
Hi @Paulinebryant13 and thanks for posting.
If you click on the highlighted link in @imjolly post it will show you how to make the required changes.
Cheers
David
