Message 1 of 3
Bt 6000
Hello I have recently purchase the above baby monitor. Just wondering if anyone can help, when I turn the lullaby on abs then press the side arrow it shows an option for 3 volume settings loud, medium and I assume a quieter one however I can only chose 2 of the volume? Has anyone had this before. Find them quite loud to have on when baby stirs at night?
2 REPLIES 2
Message 2 of 3
Re: Bt 6000
Hi @Shannyhug17, welcome to the forum, and thanks for posting. It would be best for you to contact the Product Helpdesk as they''ll be best placed to help you with this. You'll find the contact details in the link.
Cheers
John
Message 3 of 3
Re: Bt 6000
Thank you
