Message 11 of 27
Re: Bt hub
You wouldn't have been able to do it by accident, and it is not done on the hub.
Message 12 of 27
Re: Bt hub
when i look on my hub to see whats connected ive got a mixture of static ips and (DHCP) and to prove that there is nothing wrong with the ethernet cable ive got running to my bedroom ive plugged a 5 port netgear switch into to port 3 on my hub and then it shows up on my firestick upstairs that it is connected to the ethernet cable its so weired
Anonymous
Not applicable
Message 13 of 27
Re: Bt hub
Factory reset the hub and then switch Smart Setup again, the hub may be new but that doesn't mean it's above suspicion
Anonymous
Not applicable
Message 14 of 27
Re: Bt hub
Is it the devices with a static IP connection that are not working?
TalkTalk default gateway is 192.168.1.1, BT use 192.168.1.254
Message 15 of 27
Re: Bt hub
But that would need to be set on the devices though.
Anonymous
Not applicable
Message 16 of 27
Re: Bt hub
Yeah but that makes it easier to fix. Just forget network connection on the device and go for a new DHCP address
Message 17 of 27
Re: Bt hub
True
Message 18 of 27
Re: Bt hub
is there a step by step guide in to doing this as ive had about 12 yrs with talktalk but very little experience with BT ive only had it since 15th.......
many thanks
Anonymous
Not applicable
Message 19 of 27
Re: Bt hub
If it is the devices with static IP that you are having a problem with then you will need to dig out the user manual for each of those devices as the changes need to be made on them.
As a rule of thumb, if one of the devices is a TV, you will proceed as below
Enter Setup, Find Network Settings, Tell it to forget whatever settings it's currently using & go for an automatically assigned (DHCP) address. Sorry but that's the downside of Static IP, it requires a measure of technical know how when things go wrong as different devices do the same thing in different ways
Message 20 of 27
Re: Bt hub
still no joy ive done a factory reset still no joy ive changed the ethernet cable plugged it in and it worked but as soon as i connected something else to the hub it dropped the connection for upstairs agian im beggining to wonder if this was a bad move moving to bt i never had this problem when i was with talktalk
