Message 1 of 4
Bt sport with Bt mobile
Hi
i have recently joined BT Mobile, with the BT sport package included. How do I actually get access to BT Sport? When I try to log into app it tells me it does not recognise my Bt sport credentials…how do I sign up for BT sport? The only options on my profile for add-on involve a fee.
I tried calling customer support but as soon as I get passed the queue it hangs up. Helpful.
Thank you
3 REPLIES 3
Message 2 of 4
Re: Bt sport with Bt mobile
Check out the instructions for registering here: Get BT Sport on Your Mobile – Worth £10 a Month | BT Mobile
If you've already followed that process, then check out the help on validating your profile is set up correctly here: https://www.bt.com/help/id003
If that still doesn't sort your issue, send me a DM and I'll take a look at your account
Message 3 of 4
That’s worked, thanks Darren
Message 4 of 4
Hi @jd4444,
Thank you for posting back to update the thread.
I'm glad @DarrenDev was able to help.
Thanks,
Paddy
