Message 1 of 3
Bt tv recordings
Can I record BT tv programmes using my Android phone?
2 REPLIES 2
Message 2 of 3
Re: Bt tv recordings
You can schedule programmes to record on your YouView box using your mobile phone.  To do so, simply select any future/current programme from the TV Guide (found within the Live tab in the app, then the Schedule section in there), and then click the Record or Record Series button.  It'll take you through a one-time setup to pair the app with your YouView box, after which you can just click to record.
You'll then be able to watch those recordings directly on your YouView box.
Message 3 of 3
Works perfectly, thank you.
