Message 1 of 4
Deleting BT TV Pro Recordings
Spoiler
BT TV
Hi there.
We have had the Pro box for a while now and like it.  We don't record much, but this evening decided to do a little housekeeping of recordings we have watched.
The rub is, I can't quite see how to delete the programmes.  I had a look a the User Guide, but didn't find what I am looking for.
Can anyone help, please?
Tags (3)
3 REPLIES 3
Message 2 of 4
Re: Deleting BT TV Pro Recordings
Hi @MiracleMaud
There are several ways - probably the most straightforward is to
go to home page  (home button on remote)
navigate down to Recordings & Watch List and then select MYTV+
that brings up the Recordings Watch List Scheduled  page
 navigate under Recordings to the tile of the recording and then press i(nfo) button on remote
if it is a single recording you will see the option to Delete  (so press Ok if you do wish to delete)
if it is a series  or group of recordings  you will see one of the programs in the series highlighted , if that is not the one you want then navigate left or right  until you do highlight the recording you do want , then press i(nfo)  and you will see the delete options.
Other methods include using the BT Tv app on a paired mobile device - and  recent recordings that are  still in the 10  programmes listed on  REcordings & Watchlist carousel on the Home page can be deleted by selecting the program tile and using the i(nfo) OR the Record button.
Message 3 of 4
Many thanks Zulu.
Message 4 of 4
I just upgraded from an older BT 4K box to the Pro and noticed they've removed the DELETE button from the new Bluetooth remote.
The R (record) button now acts as DELETE too which is odd but is fine. No mention of that in the graphic below from the PDF userguide.
I did keep using my old remote for a few hours but the Bluetooth remote works very quickly in comparison.
