Message 1 of 3
Can BT's ONT be plugged into a surge protected plug strip instead of directly into the wall?
Hopefully not too silly of a question, I doubt there's any difference but it's always best to know well in advance as our town's in the build plan and of course I plan on getting it. I'd want the router in my bedroom but my room only has two single plug sockets in the wall, both of which have two 6-plug plug strips so I can actually use my PC, monitors, games consoles etc. Three sockets are unused and available.
2 REPLIES 2
Message 2 of 3
Re: Can BT's ONT be plugged into a surge protected plug strip instead of directly into the wall?
Yep, absolutely no problem.
Providing it's got power, plug it in where you like.
Message 3 of 3
Question answered - thank you so much, mate. I'll mark your answer as an accepted solution and consider the thread done~
