Message 11 of 12
Re: Can I increase my upload speed?
@DJF95wrote:
No, I can only use 2-3 out of the 5, or it lags like crazy. Also all through ethernet, I don't use wifi
What lags? Your posts says "upload speed".
If YOU are experiencing lags, then that is caused by, amongst many possible problems, download speed/connection!
Message 12 of 12
Read through replies, my download speed is fine. I meant the stream, the stream lags when using above 2-3mb upload speed as my upload speed can't handle it.
