Message 1 of 406
Can't update from McAfee to Norton
I've tried updating BT Virus Protect from McAfee to Norton. Press "Update" and I get a "Server Error" from Norton. I then get an email from BT to say my Norton subscription is activated. How do I download and install Norton? BT technical tells me to contact Norton which seems wrong. It passes the problem back to me!
405 REPLIES 405
Message 2 of 406
Re: Can't update from McAfee to Norton
Yes I have the same problem.
Message 3 of 406
I've noticed reading the first post on here that today is the first day you can update. Doesn't bode well does it? I did a chat with Norton and the person on the other end really didn't understand the BT connection!
Message 4 of 406
Having the same problem, server error. Glad I'm not the only one, but quick fix needed.
Message 5 of 406
Thanks all for bringing this to our attention.
We are aware of the problem and are working to fix it asap.
Cheers
David
Message 6 of 406
Hi @jimhooper , @catsatmat  and @macspot .
We would like to take a closer look at this for you so I'll drop you a private message now so you can get in touch.
Cheers
David
Message 7 of 406
Re: Important updates to your virus and password protection
Mobile app is still McAfee, requires activation code. Will it be switching to Norton.
Message 8 of 406
Hi @paularmstrong63 and welcome to our community.
Thanks for posting. The new app went live in the Google Play store around 10am this morning and will gradually get rolled out to customers over time – over the next couple of weeks. In the meantime, if you already have the McAfee version of the BT Virus Protect app installed, it will continue to work as normal. At some point later your device will receive the automatic update, which you will need to update on your device - just as you would update any app. After that, you will have to login with you BTID credentials just once to activate. Please note, we are aware of an issue preventing some customers from logging in at present. We’re actively trying to put that right. We’ll be back to let you know when we’ve resolve it.
Cheers
David
Message 9 of 406
Yes, same problem with me. Spoke to someone on BT Help line. She said they were unaware of the issue (see post by moderator on here!!!). She also told me she could do nothing and it was a Norton problem. I haven't contacted Norton yet. Will wait for this thread to resolve.
Message 10 of 406
Problems already I get any error trying to upgrade to Norton2021-12-13 11_31_54-Window.png
