Anonymous
Not applicable
Message 11 of 17
Re: Cannot connect to the internet using TP-LINK Archer 600 Router
Hello,
Followed what you told me to do but no good still cannot connect to the internet, at the end of the setup it say failed.
Any more help would be great.
Matthewatlant0s
Anonymous
Not applicable
Message 12 of 17
Hello,
when going though the setup what option do I select dynamic IP or PPPoE please let me know.
Matthewatlant0s
Message 13 of 17
PPPoE and then username is [email protected] and password is BT
Anonymous
Not applicable
Message 14 of 17
Hello,
I will reset the router again and run the setup again and enter the info you told me.
And let you know the outcome.
Matthew
Anonymous
Not applicable
Message 15 of 17
Hello,
I entered the info you sent but still have the problem,
Do I tick Enable VLAN ID or not ?
At the end of the setup get the following error message Sorry! Internet not connected. please check if your cable is properly connected.
Message 16 of 17
VLAN ID is handled by the ONT not the TP-Link.
Anonymous
Not applicable
Message 17 of 17
Just a quick update
Checked with Tp-link tech support and they told me at the router is faulty,
So will get other router
Thanks for all your help
MATTHEWATLANT0S
