Message 1 of 9
Cant text or use data
Hi anyone have any ideas why i cant text or use data on my phone? I can ring people though which makes no sense
8 REPLIES 8
Message 2 of 9
Re: Cant text or use data
Log in to your MyBT account and check whether you have any remaining data allowance for the current period.
Message 3 of 9
I have loads of data so cant be that and i dont think that would effect me being able to text. I had my number transfered from my old provider yesterday and it was working fine until last night when it suddenly went like this
Message 4 of 9
Can you receive texts?
I still think you should check your MyBT in case there is something to note.
Message 5 of 9
I can recieve texts but cannot send them. I have checked mybt and there is nothing to course this issue on there
Message 6 of 9
Have you tried a soft reset of your phone?
Message 7 of 9
Yes i have but i know its not the phone because i have tryed the sim in my other halfs phone and its exactly the same, cant text or connect to the internet by mobile data
Message 8 of 9
Ah, so the problem may be the SIM itself in which case you would need to contact the helpline.
I wonder whether the actual porting of your number went through OK.
Message 9 of 9
Was hoping you wouldnt say that because i hate phoning helplines
