Message 11 of 15
Re: Constant disconnects
Hi @Dauer,
Thanks for posting the stats. I can help with this. I'll drop you a message so you can get in touch.
Cheers
David
Message 12 of 15
Hi @DavidM replied to your PM with all the info you requested, will continue to monitor modem stats in the meantime.
Message 13 of 15
As David was preoccupied, Neil picked up my case, we discussed the whole issue a couple days ago and he recently reset my downstream SNR back down to 6 and it looks like my broadband is back in working order.
Downstream margin fluctuates a bit and there are some packet errors, but I didn't notice either of those affecting the connection stability or quality.
Message 14 of 15
Hi @Dauer,
Thanks for posting back!
I'm pleased to see that your speed is looking much better.  @NeilO is in later today and I'll let him know you've posted.
Cheers,
Robbie
Message 15 of 15
Hi Robbie,
All good on my end still, and thanks to the mod team for sorting this out.
I PM'd Neil to confirm that he can now mark the fault/issue as resolved on the system.
All best.
