Message 1 of 11
Continuing landline problem
I've posted on this previously, the problem is ongoing and I'd appreciate suggestions on what might be happening, please. My cordless landline phone has been disconnected from the phone line and power for 48 hours now. The handset is flashing for a split second at intervals between approximately 30 seconds, and three minutes. Two of us have been monitoring this with the stopwatches on our phones for over an hour.
The other two handsets are packed away in a drawer, not in use.
Any suggestions would be appreciated.
TIA.
10 REPLIES 10
Message 2 of 11
Re: Continuing landline problem
What is the make and model of the phone? Do you have a dial tone on your line?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 3 of 11
Thank you for replying
The phone is a BT8600 Trio, with answerphone. The other two handsets aren't connected. The line is working fine, I have an ancient corded set plugged into it, that's working ok too. I did disconnect that when we watched the flash timings earlier, just in case that had anything to do with it.
Figural
Message 4 of 11
My guess is that the handset, which has its own power source, is trying to tell you that it cannot find the base station
Message 5 of 11
How long might it take for the batteries to run down? I'd need to check this when the batteries are flat. The phone manual says the batteries can be removed but they can't; the instructions are wrong, there's no way in.
Thank you for replying.
Figural
Message 6 of 11
this was a previous post and they managed to remove batteries
https://community.bt.com/t5/BT-Devices/BT8600-Cordless-Phone/td-p/2034449
Message 7 of 11
Hi @Fiigural   There is a video here plus I am sure others if you search YouTube. https://youtu.be/WOl4SOBlFbI
Message 8 of 11
@Fiigural
If it's a fixed battery then it could be that the handset is trying to tell you that the battery needs charging, if so then charging it up a little should stop it flashing
Message 9 of 11
Thank you for that! I've just managed to get the battery compartment open. The manual was misleading, saying that it only took finger power :-(. Powerful but very narrow fingers seem to be needed, neither of us have those.
A narrow-bladed table knife did the trick without doing any damage. So the batteries are out and we'll be phone-watching for a while. More later.
Message 10 of 11
Still not certain what you are trying to prove
