Message 11 of 24
Re: Digital Voice migration if not using Smart Hub 2
@Will168 wrote:
@licquoricewrote:
Very doubtful, why not ask them.
Fair point. I'll ask BT next time I call them for anything. Just wondered if anyone had already had experience of it already.
Its nothing to do with BT, its Openreach's responsibility.
Message 12 of 24
I suspect Openreach will be reluctant to remove the  copper line and master socket until all service providers have moved to a VOIP system in case it is required to provide service if the houseowner changes service provider to one that doesn't provide it yet.
Message 13 of 24
Good point.
Message 14 of 24
When OpenReach did my FTTP the guy said he was ripping out the old master socket and cable and he piggy-backed the FTTP cable from the pole outside on to the old copper wire (left outside nice and tidy if need again I assume).
I was shocked they ripped out the old stuff but hey ho.
Message 15 of 24
Hi Pete @PeteCloss
I have the same situation that you raised here, I really don't want to be forced into using the BT Hub. I would be interested to know what you decided to do following the transition to Digital Voice.
Cheers
Message 16 of 24
You only have 3 choices.
Use the BT Smart Hub2 if you want BT's Digital Voice service, use a third party router and third party VOIP provider or no voice service at all.
Message 17 of 24
I removed mine, what objection can either BT or Openreach have once the copper line has been declared redundant
Message 18 of 24
See message 12
Message 19 of 24
Hi @licquorice licquorice
thanks for responding. I have FTP to an Openreach modem, can the BT Smart Hub be daisy chained in anyway via the modem or a third party router to provide just the Digital Voice Service ?
Message 20 of 24
the SH2 needs to be connected to ONT for DV
