Message 1 of 5
Digital voice
I have just had Fibre/digital installed, which comes with a special handset. Will this over-ride my Advanced Phone Quad setup.
4 REPLIES 4
Message 2 of 5
Re: Digital voice
@Acrapnell
Just plug your existing phone system into the phone socket on the back of the BT Smart Hub 2, and it will works just as it did before. The special handset is just an extra bonus, which works independently.
Its the socket shown in green, that is where your phone should plug into, just remove any sticker.
Message 3 of 5
Re: Digital voice
Thanks I got the impression that the new handset overode everything else.
Message 4 of 5
Re: Digital voice
No, it does allow you to make an additional outgoing call, even if your existing phone line is in use.
For some people, who just have a wired phone, the free DECT handset could be useful.  In your case, just plug the base unit of your existing system, into the socket on the home hub.
If that is  not convenient, then you can request a free digital voice adapter which you can plug into a mains socket and it acts as a DECT receiver, and allows you to plug your base into it.
Message 5 of 5
Re: Digital voice
OK Thanks
