Message 1 of 6
Disconnection
Recently had FTTP installed - If i power down the modem and hub and disconnect (we have carpet fitters coming!) When i reconnect and power up will i need to reset anything? Or will it just restart and be as normal....Thanks
5 REPLIES 5
Message 2 of 6
Re: Disconnection
It will just restart.
When you say disconnect, what are intending to disconnect? Do NOT remove the optical cable to the ONT.
Message 3 of 6
Re: Disconnection
@Geoffgp
There should be no issues on an FTTP connection, but see warning from @licquorice
Message 4 of 6
Re: Disconnection
Just disconnecting the power from the modem and hub, and the ethernet cable from the modem to the hub.
Message 5 of 6
Re: Disconnection
Then, no problem.
Message 6 of 6
Re: Disconnection
Many thanks
