Message 1 of 5
File download issues.
I have an issue downloading a specific file any help appreciated.
I am getting timeouts when trying to download content from CDN77, the download stops after about 10 to 40mb. The content is coming from the domain download-center.dxo.com which resolves to  185.59.221.21,  89.187.167.3, 195.181.164.15 on a round robin basis with a TTL of 10 seconds. I have tried many times and am unable to download the file on BT. I have tried on 3 other ISPs with no issue, note that these ISPs get the same DNS response and therefore use the same CDN servers as I am using on BT.
I have the issue on all devices OS X, iOS and windows and have tried different browers.
4 REPLIES 4
Message 2 of 5
Re: File download issues.
Go into MyBt and switch BT Web Protect off
Message 3 of 5
Hi @M5zap and welcome back. It's been a while.
Can you give @Les-Gibson advice a go and let us know if that helps?
Cheers
David
Message 4 of 5
Hi David
I have checked and BT Web Protect was already set to off.
The download does start and then stalls early on in its download. The stall point is variable.
Message 5 of 5
Thanks for checking that @M5zap .
I think we need to take a closer look at this for you so I'll send you a private message so you can get in touch.
Cheers
David
