Message 1 of 7
Dtr-2110
Moved house and have a new BT Halo hub which is connected to internet. On reconnecting my DTR-2110 Freeview box it does not connect to the hub?
Tags (1)
6 REPLIES 6
Message 2 of 7
Re: Dtr-2110
have you turned of smart setup
Turn Off smart setup
Message 3 of 7
Re: Dtr-2110
Switched Smart Setup on hub to OFF. No difference, DTR-2110 still not seeing internet?
Message 4 of 7
Re: Dtr-2110
How is the DTR-2110 connected to the hub?
Message 5 of 7
Re: Dtr-2110
Standard Cat 5 cable into a port
Message 6 of 7
Re: Dtr-2110
Tried rebooting the hub?
Message 7 of 7
Re: Dtr-2110
@Jim53
I'd look at the network settings on the T2110 and ensure that it's not been set manually previously with any details not compatible with the new hub.
Also is that a new cat5 cable or one that was in place already and can you try another cable and port etc.
