Message 11 of 30
Re: Email not working
Hi @Neville1999, welcome to the forum, and sorry you are getting this error message.
If you're still experiencing this problem and you're using a VPN (Virtual Private Network)? Would you try disconnecting it?
If that doesn't help would you please answer the below questions for us?
Which countries have you tried to access your account from? (this may just be the UK)
What type of device are you using ? Laptop/tablet/mobile ?
Are you using a web browser (Chrome, Internet Explorer or Edge etc) or BT Webmail?
Cheers
John
Message 12 of 30
Yes John, I was using VPN and so I did turn it off after reading comments, and yes that did seem to fix it!!
I am in the UK
Thanks for your comments
Message 13 of 30
I'm having exactly the same error accessing MyBT having had BT Broadband installed last week.
Before installation it was fine and since, but I got the error for the first time today.
I am using a Work laptop and have  cleared cookies (used incognito session to make sure none were set) but my employers enforce the use of a Forcepoint proxy for all internet access, whether the VPN is active or not.  This setup hasn't changed (to my knowledge) so why have I only just got the error for the first time?
Can the Forcepoint proxies be added to a White list or is there some other way my access can be restored?
Message 14 of 30
Having same issue. Has been fine for years, and now suddenly stopped.
Same VPN (work) as previous, now cant access account.
Zscaler is default work environment application
Message 15 of 30
This is an intermittent problem which only occurs when accessing from a PC. I don't use a work VPN. I'm accessing from the UK. There is usually no problem when logged into a BT internet connection. The problem occurs when I try to access email from my PC while logged on via a different internet provider.
Message 16 of 30
Is there a fix for this because the problem has started for me today. I can't get to my emails in the web-browser, can't login to my BT account of BT cloud. What's changed on the BT end? Nothing new on my end.
I have to use zscaler because it's my work laptop. I tried clearing cache, cookies, tried Chrome, Edge, Firefox. Tried restarting my laptop. Same error code every time.
Sorry we couldn't connect you. If you continue to experience issues, Please contact BT and quote Error Code: TS-0003
Message 17 of 30
So my e-mail on my work laptop has stopped working this morning same message as before:
Error Code: TS-0003
Yes I have a VPN, we use Zscaler which appears to be a fairly common among those experiencing this problem.  I cannot turn the VPN off and it is not affecting other devices.
Message 18 of 30
Problem back again, nothing changed on my side, This seems to be a BT generated issue
Message 19 of 30
I have also started getting this exact problem.  I can connect to BT email using BT as the service provider but cannot connect on my other (main) provider.     As an aside, the email login has also started taking 3 or 4 minutes to connect which is painful.  This all started on 10/2/22 and I am in the uk.   What can I do?
Tags (1)
Message 20 of 30
Well,  mine started working again after 3 days. No action on my part!
