Message 1 of 6
Engaged tone to outside callers
Hi,
Our callers to our landline complain of engaged tone when calling all the time. There is no dial tone also from our side.
I read a similar thread on this site and joined for your help. Was this resolved?
is this a line fault?
Thank you
Naveed
5 REPLIES 5
Message 2 of 6
Re: Engaged tone to outside callers
if you have no dial tone then report phone fault to 151 or 0800800151 from mobile
Message 3 of 6
If you have NDT and in coming callers get an engaged tone that would usually indicate you have a Fault Loop, aka Short Across the Pair.
A fault like that could occur literally anywhere in the Network.
Message 4 of 6
Hi @NTuf,
Welcome to the Community and thank you for posting.
What @Starwire and @imjolly have said is correct. The quickest way to get your service repaired is by giving 151 a call.
Once you've given them a ring, please post back and let us know how you got on?
Thanks,
Paddy
Message 5 of 6
Thank you
Message 6 of 6
Have you tried a known working corded phone in the test point of your main telephone? The fault could be caused by a faulty piece of equipment or cable in your house.  If by plugging the phone there is still no dial tone then the fault is out of your house.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
