Message 1 of 46
Error code VC019
I have a Samsung smart TV and I can play the channels on at that moment but everything else I try to watch comes up with the error code. I don't have a PlayStation or anything & other apps are working fine.
Please help as I'm pulling my hair out missing everything
45 REPLIES 45
Message 2 of 46
Re: Error code VC019
If you're able to watch live TV but the clips/highlights are all failing then it sounds like you're either unable to contact (or are being blocked from contacting) our on-demand video service.
The simplest thing to check first would be a reboot of your TV, your internet router, and anything in between (e.g. wifi extenders, powerline adapters, etc).  Let us know how you get on.
Message 3 of 46
I have same issue on brand new Smart 4k QLED Samsung TV.  I can play Live streams but on anything else I get VC019 error.  I've checked settings all is fine.   Wifi/router is fine as all BT sport streams work fine on my Android phone & Windows Laptop.  Strangely enough, I have another 3 year old Smart Samsung TV in another room that again all streams works fine.   What is the problem?
Message 4 of 46
Send me a DM with the BT ID you're logged in with @h1208nez and I'll see what your TV doesn't like
Message 5 of 46
@h1208nez unfortunately your TV is doing the same as described in https://community.bt.com/t5/BT-Sport-on-TV-Online-player-or/Only-Ultimate-Channel-will-work-on-Samsu...
I can only recommend you try the steps detailed on my last post there.
Message 6 of 46
Ok will have a look thanks
Message 7 of 46
Ive already re-installed App and TV software updates automatically.  will get in touch with Samsung
Message 8 of 46
Ok, ill give it a go. I have a Samsung 32in upstairs that does exactly the same thing
Message 9 of 46
@DarrenDev
re-installed BT App,
reset factory setting on TV
updated software
Reset Router
Contacted Samsung.  They've checked and say "it seems that this is down to server error.  However as we don't have access to the app code we cannot amend it.  Have you checked with BT if they will release any future updates"
Is this likely?
To clarify, brand new Samsung TV gets VC019 code when accessing On-demand content.  Its perfectly fine with Live streaming.   I can watch On-demand & Live on all other devices including older version of Samsung TV.
Message 10 of 46
@DarrenDev @Diane753
Online with Samsung's in-built TV browser, can watch on demand, but can't on BT Sport App.  Definitely Code issue somewhere!
