Message 31 of 46
Re: Error code VC019
VC019 is a common error code to all platforms, just meaning an error occurred when trying to start the video. It has numerous different causes on each platform.
In your particular case, the TV is just telling us "prepare failed" - a generic error meaning that the player failed to load the content. It doesn't give us any further explanation.
Our logs indicate that you issue is intermittent, and we can see some examples where a video has played ok for you, where it previously failed with VC019.
We can also see in many cases that you tried to start a video, but our logs show no attempt by your TV to download the video from us.
Together, these signs suggest an issue with the network connection.
How is your TV connected to your internet? Do you see any issues at all with other apps on your TV? When you next see this error, could you immediately try another streaming app on the TV? What quality of video are you getting from other apps? Could you use the device checker within the BT Sport app (accessed from the cog in the top right) to test what it believes your connection speed to be?
We have also had some success with customers calling the Samsung help desk for this issue - they're able to see more information about what is happening on your TV. Customers have told us that Samsung have managed to fix the issues for them remotely.
Our logs aren't indicating a widespread issue, however usage is low outside of the football season so it's hard to prove anything one way or the other.
Message 32 of 46
@DarrenDev
I've already replied to issues you raise.  In my case, its not internet connection as no issues with other devices except the one Samsung TV.
On same TV, I can watch "On Demand" BT Sport through its browser but not through BT App.  Both TV & BT App have had updates/re-installed.  I've been in touch with Samsung.  They've checked TV & said it's a code issue that needs resolving with BT App.
I've unsubscribed until I hear issue is fixed.  As I've mentioned before my TV is Q80A (2021) QLED model.
Regards
Message 33 of 46
I have the same issue. I can watch live tv but no catchup, highlights or the bt films.
This has worked fine for me for nearly 2 years - last 2 weeks stopped working.
I have totally reset samsung tv and obviously de/reinstalled bt sport. All is upto  date but no joy.
Samsung tv 1 x 55” QN94A Neo QLED 4K HDR Smart TV (2021)
QE55QN94AATXXU
BT says i do not have large screen addon - I do have this.
EE says to call samsung.
Samsung say bt sport issue
This is clearly an issue - even if not a big issue.
I see it that bt app is made for devices so it is for bt sport/ee to liaise with manufacturers to ensure their products work on the platform. If you tell me it doesn't work on samsung tv's anymore ( 2 years work fine!) then ok and i can cancel subscription - not a good business model for btsport i think...
Anyone help here ?
Message 34 of 46
Hi mrbatch,
I had the same issue with my Samsung tv, it might be worth putting the tv on a hot spot and see if it works off that.
I ended up moving my broadband to bt and which resolved it
Samsung believed it was a conflict on the talktalk router trying to use ipv6 but talktalk didn’t support ipv6 yet on the broadband
Message 35 of 46
@collings99
thanks for reply - we are in countryside with no fixed broadband so use mobile EE sim in router. so in house phone & laptops (which work fine) and tv ( which only shows live not catchup/on demand) are effectivly on the same network with eiter ipv4 or 6. ie if phone works so should tv
Message 36 of 46
It could still be the ee router causing the issues. All other devices worked on my talktak broadband it was just the why the tv was trying to talk to bt servers for the replays. Live streams and full programs were on a different server I believe.
If you were able to hotspot off your phone rather than using the router and it works, it proves it’s the router. EE is part of bt so would be probably be able to look into this more I would imagine as it’s all there kit techincally.
@DarrenDev managed to get Samsung to contact me to run some diags which they then feed back to bt
Message 37 of 46
Update for my Samsung TV which is completely reset, latest firmware and latest BT sport app
1. No catch up/ highlights at all using samsung bt app on my normal router via wifi but live tv is shown so app os working of sorts.
2. Plug in roku stickto the samsung tv using same normal interent - works fine. Implies it IS NOT my normal internet and samsung displays  so bt sport app at fault for point 1
3. Put samssung tv on my phone hotspot. Built in BT app works ok. Implies IT IS my normal internet.
Summary - the issue seems to be only my normal wifi (which is via a mobile sim with EE) AND bt sport app direct.
People have mentioned ip6 and silverlight in the past as possible issues. Can anyone from bt @DarrenDev @SeanD look forther at this to get a resolution.
Message 38 of 46
@mrbatch
@collings99
@DarrenDev
I have same issue which hasn't been resolved by BT since I raised it 12 months ago.  Its not Ip6 or Ip4.  I use Talktalk.
My Samsung Q80 TV only gets live streams and BT Channels on the App but nothing on demand.  Funnily enough, I can get them using Q80's browser but not on BT App.  I can also get them on all other devices in the house including an older Samsung TV.
Samsung told me its code issue with BT App.  Judging by all other updates, it remains to be.
Message 39 of 46
I can only go off my experience and what Samsung techs told be and they believed it was my talktalk router causing a conflict with ipv6 and how the tv was trying to connect to the bt servers via the tv
If I used my phone as an hotspot the bt app worked fine for everything on my Samsung tv but as soon as I switched back to the talktalk router the issue presented again I.e highlights and replays didn’t work. But live stream and full shows worked.
all other devices worked fine in the house it was just the tv that had issues with the bt sports app.
since moving to bt I haven’t had and issue, this is not a solution as it needs to be resolved as it should work across all connections.
Message 40 of 46
Take your point. Unfortunately hotspot didn't work for me. Will consider changing talktalk though as contract about to end. ATB
