Message 11 of 20
Re: Error message
That could be a bit tricky as being abroad for long periods also breaks the terms and conditions of the email service.
If webmail isn't working either, it might not resolve your problem in any case.
Try using a different internet provider if you can and see if that works.
Message 12 of 20
Re: Error message
Hi @suzysam
Thanks for posting back.
What also might be the issue is the IP address you've been allocated while abroad has been marked as sending spam. (which would be why this only started recently).
Check this link to see what your IP address is - What's my IP address?
You can use this tool to see if the IP address is on a blacklist - Email Blacklist check
Let me know how you get on.
Cheers,
Robbie
Message 13 of 20
Re: Error message
Thanks Robbie,
Emails have been working fine for a while, maybe the IP address has recently been added.
I’ve spoke with BT customer services and they are investigating.
Thanks to everyone for your replies, really appreciate your help.
Message 14 of 20
Re: Error message
Definitely worth trying using a different provider if you can as that will give you a different IP address as well as checking if your provider is blocking the mail.
Message 15 of 20
Re: Error message
Just a follow up.  I have tried to send emails from a few different computers (all with different IP addresses/service providers), none will send and all give the same error message, so don't think this is the problem. 😞
Message 16 of 20
Re: Error message
Thanks for ruling that out as a potential issue @suzysam 😊
At this stage, we can pick this up and do some digging to find out why you're presented with that error message.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Message 17 of 20
Re: Error message
Hi Suzysam,
If you reply to Robbie's message anyway and send over your info the moderation team will be happy to raise this with our email specialists. It looks like there may be a false positive Spam marker on your email or IP addresses of the country you are visiting. We have avenues into the correct email teams to raise these types of issues.
Neil
BT Community Moderator
Message 18 of 20
Re: Error message
Hi Robbie,
No VPN and I have tried to send emails from
different computers (with different service suppliers).
Regards
Suzanne
Message 19 of 20
Re: Error message
Hi @suzysam
I'm sorry that you're still seeing this error message and that you haven't heard any word back from my colleagues.  I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Message 20 of 20
Re: Error message
Hi @suzysam, thanks for getting back to us, and great to hear it's working ok for you now.
cheers
John
