Message 1 of 23
Ethernet Cable putting me on different network
So we recently got a new BT router and I use a direct ethernet to connect to the router, however, it isn't putting me onto our BT network, it is putting me onto our Sky Network despite being directly connected to the BT router? It does the same thing to my brother who is also directly plugged into the BT.
I've tried resetting the router, factory resetting the router, resetting my PC and ethernet Card but nothing seems to work.
Any help is appreciated!
22 REPLIES 22
Message 2 of 23
Re: Ethernet Cable putting me on different network
Has your internet connection actually been changed from Sky to BT?
Message 3 of 23
Can you post a tracert to bbc.co.uk?
Message 4 of 23
Do you use powerline adapters?
Anonymous
Not applicable
Message 5 of 23
I'm pretty sure I know the answer to this one from personal experience.
Make sure your machine is connected to the hub
Go into settings, in the search bar - type Network Reset and press enter
Answer Yes when prompted
Your machine will tell you that it's going to reboot in 5 minutes but there's no need to wait, just restart it yourself
That should be all you need to do
Anonymous
Not applicable
Message 6 of 23
That's exactly what happened to me
Message 7 of 23
@Anonymous  An easier way would be open a command prompt then type "ipconfig /release " then ipconfig renew"
(no quotes) no machine restart required.
Anonymous
Not applicable
Message 8 of 23
@pippincp
For whatever reason, that didn't work for me, on top of that some people baulk as soon as you tell them to open a command window and mention DOS. That's why I suggested the reset
Message 9 of 23
No, we're still on BT, we have two different internets
Message 10 of 23
No I don't, I'm connected via 20m ethernet cable straight from my PC into the router
